J_Dau
Hi Dirk
im deutsche Wikipedia hab ich nichts gefunden. Weiter unten findest Du den Artikel aus dem englischen Wikipedia.
Eine taktische Lampe kannst Du an einer militärischen (oder polizeilichen) Dienstwaffe befestigen.
"Tactical light
From Wikipedia, the free encyclopedia
A tactical light is a firearm accessory that aids in low light target identification and allows the marksman to simultaneously aim and illuminate the target, since the light is mounted co-axial to the bore. Tactical lights can be fitted with lenses to produce certain colors, including light in the Infrared spectrum, which is only visible through certain goggles.
Tactical lights have also been modified as non-lethal devices designed to incapacitate a target instantly without permanent effects and gain a tactical advantage. A tactical light is usually made for a specific model or class of firearm. Hanguns often require a unique light for each model, while larger weapons can use Weaver rails or barrel clip to mount universal designs.
Tactical lights are also sometimes combined with a laser to form a multifunction unit."
"Tactical light
